Location: Renegade Zone \ Renegade Zone \ Maps/Mods \ Installing a Mod/Map Back to Threads |
Thread is Locked
New posts and follow ups may not be made within this thread.
This is a Sticky Thread
Renegade Zone
![]() Joined: 17 September 2003 Posts: 15 |
01 November 2003 11:14 (UK time)
I get so many emails on how to install a Mod/Map so I have listed basic instructions below: - ============================== ==Installation Instructions=== ============================== 1. Open up the .zip file for the map. 2. Read the readme (if there is one) 3. Extract the .mix, .pkt etc file to the folder :\Westwood\Renegade\Data 4. Boot up Renegade 5. Go to LAN game (or you can go to a server playing the mod and just join the game). 6. Host a game. 7. Set the players to 1 (if you are testing or playing map on your own). 8. Make sure it is NOT a dedicated server. 9. Choose the mod from the mod package dropdown list. 10. Play the map. ============================== ====Uninstall Instructions==== ============================== 1. Open up My Computer 2. Go to the folder :\Westwood\Renegade\Data 3. Delete the map/mod file, making sure that it has a .mix and .thu or just a .pkt etc extension. You need to login to create posts in this thread. |
