Location: Renegade Zone \ Renegade Zone \ General \ got a problem :( Back to Threads |
Duckeh364
Posts: 3 |
04 December 2003 14:41 (UK time)
hi their I am a renegade player and I play renegade mutch but yesterday I got a virus so I hade to re-install renegade but now I cant play it any more this is the problem that I get Your installed verison of Westwood online is incompatible with this porduct. Please reinstal the Westwood online component can you guy's tell me how I could do that?? You need to login to create posts in this thread. |
im zop6593
![]() Joined: 06 December 2003 Posts: 14 |
06 December 2003 10:56 (UK time)
all i can think of is to completly uninstall renegade and then install it again it might work but im not to sure You need to login to create posts in this thread. |
Duckeh364
Posts: 3 |
07 December 2003 12:41 (UK time)
thx man I will try right now I will tell if it works You need to login to create posts in this thread. |
Duckeh364
Posts: 3 |
07 December 2003 18:40 (UK time)
thx its working again You need to login to create posts in this thread. |
im zop6593
27 December 2003 17:37 (UK time)
no problem m8 You need to login to create posts in this thread. |
