Renegade Zone  \  Renegade Zone  \  Maps/Mods  \  Harvester help
Viewing Thread: Harvester help
14 March 2005 02:58 (UK time)
I just recently made my first map with a refinery and havesters. I downloaded tutorials of what i needed to do in order to get havesters working, they helped me out but im hveing some problems. First off my GDI havester works so i dont need help with that but the thing is with my NOD havester, after it gets created it moves down the airstrip a little then stops and does nothing. Then a few seconds later the cargo plane comes and drops off another one. i have already checked my waypaths and they seem to be fine. My problem may be that i have accidentily put 2 nod refinerys but... idk. can some one please help me out?
14 March 2005 03:43 (UK time)
Idk what to tell you if you have msn you can send me your map and I can try to fix them my msn is bad_fur_day_07@hotmail.com ive had this issue accept it was just that the harvester would stop and not move but another 1 didnt come out.
14 March 2005 03:45 (UK time)
k, will do
Edited: 14 March 2005 03:45
