Location: Renegade Zone \ Renegade Zone \ Maps/Mods \ Scripts Back to Threads |
26 February 2005 05:09 (UK time)
Does any 1 know where i can find a list of what all the scripts are and do, or if they have time type them and post em You need to login to create posts in this thread. |
![]() Joined: 02 February 2004 Posts: 90 |
26 February 2005 05:34 (UK time)
Did you try www.renhelp.co.uk in scripts section? You need to login to create posts in this thread. |
27 February 2005 04:54 (UK time)
ya, that place sucks, theres only like 7 or 8 differnt scripts You need to login to create posts in this thread. |
24 March 2005 20:57 (UK time)
Well you know most of the scripts stuff, well wat they do is in there name for example the 1 for teleporters has the name teleporter in it and stealth zone has stealth zone in it. Im pretty sure if you find away to contact johnathan wills he knows all that stuff cause he helped create alot of renegade and renegade2 I believe. You need to login to create posts in this thread. |
25 March 2005 04:43 (UK time)
Ok here is a hufe list of scripts lol from renhelp doc Scripts Explained Visit Here For The Most Recent Version First version of this, i will do what i can to get it more updated, and more explained... as well as some pictures, and samples as soon as possible, i have a lot on my tray right now, so i am doing what i can... This is kind of a "work in progress", i will be working on this as i can, and updating as frequent as possible. If you have any suggestions, or other scripts that you have heard of or found, please email me with as much info on them as you can @ dante@cncrenegade.info AI Scripts Building Scripts Sound and Cinematic Scripts Game Mode Scripts Zone ONLY scripts Single Player ONLY Scripts Miscelanous Scripts -------------------------------------------------------------------------------- Useful Found AI Scripts Scripts used to attach to AI bots, to make them do useful stuff. M00_Action **coming soon M00_Base_Defense Use this to make soldiers/vehicles attack targets MinAttackDistance: just as the name states MaxAttackDistance: again, just as it states, in meters AttackTimer: number of seconds in between when it looks for another target PDS_Test_Follow_Player Bots run and follow player(s), right up there butt, but they follow them. M01_Hunt_The_Player_JDG To make the "Bots" look for the player.. similar to PDS_Test_Follow_Player M04_Hunter Similar to above, but makes them "less annoying". PDS_Test_Follow_Waypath Will make a unit/vehicle follow the requested waypath WaypathID: the id of the ENTIRE Waypath WaypointStartID: the FIRST triangle of the waypath WaypointEndID: the LAST triangle of the waypath **when using this, if you want the unit/vehicle to stay on the path, make it looping, and make sure the unit/vehicle has DIRECT line of site to the startID PDS_Test_GoTo_Player Unit this script is attached to will "goto" the players current position M03_Engineer_Repair Attach this to your Engineer's to have them repair units/objects with the M03_Engineer_Target script attached. RepairPriority: The priority inwhich to repair this unit/object (default:96) M03_Engineer_Target Use this to define units/objects for the M03_Engineer_Repair script RMV_Toggled_Engineer_Target Untested Engineer script Poke_And_Play_Cinematic Attached to a unit/object, this script will play the designated text cinematic when poked ("E" or action key) ControlFileName: name of the *.txt to play ("yourscriptname.txt" GTH_Drop_Object_On_Death Will create an object, once the object that holds this script is destroyed. Drop_Object: this is the PRESET name of the object to drop. Drop_Height: this is a modified z location to drop the object, use alot of testing to get this right. Probability: % chance that this object will be created. M00_Select_Empty_Hands Exactly as the name states, used in Tutorial mission, not tested in MP... M00_Permanent_No_Falling_Damage_IML Will prevent a unit that this is attached to from recieving falling damage. M00_No_Falling_Damage_DME Like above, only temporary, usually used for drop scripts. M00_MutantHeal_Script_JDG Attached to a unit, this script will make a character heal in tiberium rather than be damaged. M08_Petra_A_Unit Currently Untested for behavior results M03_Commando_Script Currently Untested for behavior results M04_A01_Sniper_JDG Currently Untested for behavior results M04_ApacheRoom_Sniper01_JDG Currently Untested for behavior results M04_APacheRoom_Sniper02_JDG Currently Untested for behavior results M05_ParkSniper Currently Untested for behavior results M04_EngineRoom_ChiefEngineer_JDG Currently Untested for behavior results M07_Bridge_Civ Currently Untested for behavior results M07_Dead6_Engineer Currently Untested for behavior results M01_C130_Dropoff_Dude_JDG Currently Untested for behavior results M03_Base_Patrol Currently Untested for behavior results M03_Base_Harvester Currently Untested for behavior results M03_Damage_Modifier_All Currently Untested for behavior results M07_playertype_Neutral Currently Untested for behavior results M08_Enable_Stealth Currently Untested for behavior results M08_Sniper Currently Untested for behavior results M09_Damage_Modifier Currently Untested for behavior results M10_TestStealth Currently Untested for behavior results PDS_Test_Modify_Attack Currently Untested for behavior results -------------------------------------------------------------------------------- Useful Found Building Scripts Various Building Scripts that can be attached to building controllers M10_Con_Yard_Repair Currently Untested for behavior results M10_Con_Yard Currently Untested for behavior results M03_Structure_Powerup_Drop Currently Untested for behavior results M03_Refinery Currently Untested for behavior results -------------------------------------------------------------------------------- Useful Sound and Cinematic Scripts Various Sound And Cinematic Scripts, these are good to attach to "ghost" objects that you create M00_Play_Sound Use this script to play a sound... useful for attaching to NEWLY spawned or made items. Sound_Preset: this is the Preset Name for the sound. Is_3d: Select either 0 for no, and 1 for yes OffSet: the location Offset of the sound.. this will take the CURRENT x,y,z and add these modifiers. OffSet_Randomness: takes the offset, and adds a randomness to it. Frequency_Min: the sounds "minimum" frequency (volume related) Frequency_Max: the sounds "maximum" frequency (volume related) M00_Play_Sound_Object_Bone_DAY Currently Untested for behavior results M00_Set_Background_Music_DAY Will set the current levels background music. MusicFile: this is the sound file in mp3 format (ex. mySong.mp3) M01_Flyover_Generic_Script_JDG Currently Untested for behavior results RMV_Sound_Play_Near_Player Currently Untested for behavior results Test_Cinematic This script will play the designated cinematic upon CREATION of the attached object. ControlFilename: *.txt filename of desired cinematic script(ex. myCinematic.txt) M09_Chinook_ParaDrop Currently Untested for behavior results -------------------------------------------------------------------------------- Game Mode Scripts Game mode variation scripts, currently only one, and it don't work right, but i thought i would explain it anyway. GTH_CTF_Object2 Here is the direct quote from the scripts comments by Greg Hjelstrom: /* ** GTH_CTF_Object2 ** This script will make the object it is attached to behave kind of like a CTF "flag" by ** attaching to the opposing player who pokes it. If its position gets within a ** certain distance of the "enemy home" an internal counter is incremented. Once the counter ** reaches a desired number, an object in the level is destroyed. This object should be the ** only building owned by the flag's team so that they immediately lose. ** ** You should use this script on an object that has "projectile" collision only. Make a model ** of your "flag", give it projectile collision and make a preset for it similar to the "Marker_Flag" ** in LevelEdit (you can find "Marker_Flag" under Object->Simple). ** ** CTF Rules as implemented: ** - this script controls how many flag captures cause a win ** - enemy poking the flag attaches it to him ** - enemy teammates can take the flag from each other ** - friend poking the flag sends it back to its initial position (only if its not carried by an enemy) ** - enemy getting the flag to his home position increments an internal counter ** - when win count is reached, all of the "Win_Object_To_Kill" objects are destroyed (make sure ** this destroys all of the enemy team's buildings ** ** Params: ** Update_Delay - how many times per second to update (this will *always* be laggy though...) ** Enemy_Player_Type - type of player that wants to grab this flag (0=Nod,1=GDI) ** Enemy_Home_Position - when flag gets here, capture count increments! ** Home_Radius - how close to home position we need to get to count ** Captures_Needed_To_Win - after this many captures, we destroy the token "building" for the win ** Flag_Stolen_Wav - wav to play when the flag is stolen ** Flag_Lost_Wav - wav to play when enemy team gets flag back to Enemy_Home_Position :-( ** Flag_Saved_Wav - someone killed the guy stealing the flag! ** Captures_Exceeded_Wav - flag has been captured "Captures_Needed_To_Win" times. ** Win_Object_To_Kill0 - object that we destroy when the capture count is reached ** Win_Object_To_Kill1 - object that we destroy when the capture count is reached ** Win_Object_To_Kill2 - object that we destroy when the capture count is reached ** Win_Object_To_Kill3 - object that we destroy when the capture count is reached ** */ -------------------------------------------------------------------------------- Zone Only Scripts Zone only scripts, attach these to a normal Script Zone, and wala... new effects ![]() GTH_Create_Object_On_Enter **coming soon GTH_Drop_Object_On_Death_Zone **coming soon GTH_Enable_Spawner_On_Enter **coming soon GTH_Zone_Send_Custom **coming soon M01_Use_Ladder_Zone_JDG **coming soon -------------------------------------------------------------------------------- Found SP re-usable scripts SP only scripts, these will NOT work in MP mode. GTH_Create_Objective **coming soon GTH_On_Enter_Mission_Complete **coming soon GTH_On_Killed_Mission_Complete **coming soon GTH_Objective_Complete_Enter_Kill_Poke **coming soon Some Miscelanous Scripts Various scripts without category. M10_Radar_Scramble **coming soon M10_Radar_UnScramble **coming soon GTH_Credit_Trickle **coming soon GTH_User_Controllable_Base_Defense **coming soon M00_GrantScore_Powerup **coming soon M00_GrantPowerup_Created **coming soon M00_GrantMoney_Powerup **coming soon M00_Disable_Transition Use this script to disable Transitions on vehicles. You need to login to create posts in this thread. |
![]() Joined: 13 November 2003 Posts: 90 |
25 March 2005 17:17 (UK time)
I cant find a good way to do this... I'm making waypaths for my bots. I want them to follow it but when they see an enemy then stop and attack it. Then after it is gone, continue on their waypath. How do i do this? You need to login to create posts in this thread. |
28 March 2005 06:55 (UK time)
ok first of all... WOW THANK U SO MUCH FOR THAT LIST I NEED IT BAD! and second i am makeing aomething just like that and have the same exact problemi used m03_Base_Patrol but all they do is walk slowly, walk into walls and when they come incontact w/ the enemy they attack it but dont go back to there path. You need to login to create posts in this thread. |
