Location: Renegade Zone \ Renegade Zone \ Maps/Mods \ Vehical AI bots Back to Threads |
22 February 2005 22:05 (UK time)
I like making maps with lots and LOTS of AI on it (inf) but i want to also add vehicular AI but i dunno what script to put on it. I want the vehical to be like the inf, attack any thing that moves. But i cant find the right script, I already tried M00_Base_Defence but all it did was point the barral the opposite way and fire onto the sky. So if any one know the answer You need to login to create posts in this thread. |
![]() Joined: 02 February 2004 Posts: 90 |
23 February 2005 22:54 (UK time)
Have you treid JFW_Custom_Destroy_Object ? You need to login to create posts in this thread. |
![]() Joined: 13 November 2003 Posts: 90 |
25 February 2005 14:06 (UK time)
Attack anything that moves, including its own team? Then you can use M03_Goto_Star You need to login to create posts in this thread. |
26 February 2005 01:58 (UK time)
Well attacking ur own team could be usefull in my "Mind control" map but i only want ones that attack the enemy for now You need to login to create posts in this thread. |
26 February 2005 19:55 (UK time)
Have you tried i think its M05_Nod_Gun_Emplacement. The only bad thing about it is, if gdi shoots their own team and they have that script, then they will shoot back. You need to login to create posts in this thread. |
27 February 2005 04:56 (UK time)
k, ill keep that in mind, will it also let the tank roam freeley? if not that do u now any thing 4 that? You need to login to create posts in this thread. |
28 February 2005 19:30 (UK time)
To roam around either make a way point. Or you can add M00_Hunt_The_Player_JDG im not sure if that the exact script, but its something similar. This will make it Go towards enemies that are near by. If there are none nearby then it will follow a human player on its team. I know a few scripts since i used to do drop mods ![]() Edited: 28 February 2005 19:31 You need to login to create posts in this thread. |
01 March 2005 00:04 (UK time)
awsome, thx thats perfect!!! You need to login to create posts in this thread. |
04 March 2005 01:31 (UK time)
If by some chance u come accross something u think can help me plz tell me. THX for ur support! You need to login to create posts in this thread. |
