Renegade Zone  \  Renegade Zone  \  Maps/Mods  \  This just seems amaze me
Viewing Thread: This just seems amaze me
22 February 2005 02:47 (UK time)
Ok this is the issue that if you guys have this problem now u can fix it.Well you see I was making a map called C&C_MountainRise and I was just finish up the map I was adding textures and this weriod thing accured I had my tiberum feild touching the ground like it should be and I went to apply texture when I press apply it turned my feild grassy like my plane so I wonder for awhile and then I saved my file quit renx/gmax and restarted applied new texture and it worked. And awhile i had this problem and restarting didnt work so I took the tiberum feild out of the plane and way off to the side and then textured it and if thats not your problem its prolly cause when you converted it to edit mesh you hit the attach tool and it attachs them together so that should help you out if you have that problem ever.
22 February 2005 04:10 (UK time)
The problem im haveing right now... I applied two textures (which shouldn't change anything) and deleted a building (technically its a box thats been edited with boolean) then made a different object and now whenever i try to open it says it can't open it. Luckily i have a fairly recent W3D version of my map but now three buildings will go untextured, one of which i dont even want :/
24 February 2005 00:08 (UK time)
So you tried createing your own buildings?
24 February 2005 03:10 (UK time)
technically yes, but i dont mean i tried to make a war factory or soldier factory or anything. I just mean a plain building that you can just go in and out of n junk. Its a roleplay map.
25 February 2005 23:30 (UK time)
Hey Bisen do you have msn this would be easier to talk about on there cause this is to much work signing in an all that and find the post lol if you do add me bad_fur_day_07@hotmail.com
26 February 2005 19:58 (UK time)
I have AIM for instant messaging and yahoo for email.
27 February 2005 00:06 (UK time)
So why dont U just download MSN LOL
28 February 2005 19:31 (UK time)
NEVER!!!!!
01 March 2005 22:54 (UK time)
Fine be that way terd!
