Location: Renegade Zone \ Renegade Zone \ Maps/Mods \ Help im so stupid Back to Threads |
Linkmsg92
![]() Joined: 29 January 2005 Posts: 2 |
02 February 2005 22:13 (UK time)
I cant figure out how to get my mmaps to work, anyone got deirections for me? Very Appreciated. -Mike You need to login to create posts in this thread. |
![]() Joined: 13 November 2003 Posts: 90 |
03 February 2005 19:23 (UK time)
What do you mean. When you make it .mix? What exactly goes wrong? You need to login to create posts in this thread. |
04 February 2005 00:39 (UK time)
go to cncden.com, there is a great map tutorial. it will explain Gmax and the level editor. also check out www.renhelp.co.uk that place is the best place for tutorials. You need to login to create posts in this thread. |
![]() Joined: 02 February 2004 Posts: 90 |
22 February 2005 02:49 (UK time)
Well if your problem is after you exported it to level edit make sure you exported it as .w3d and check the renegade terrain circle if thats not it you prolly didnt save your file it sometimes happens make sure you click save as so you can find out where you saved it and what it saved as cause it doesnt always save as your maps name unless you click save as. You need to login to create posts in this thread. |
