Renegade Zone  \  Renegade Zone  \  Maps/Mods  \  map makers i need help
Viewing Thread: map makers i need help
bryan919
23 January 2005 23:40 (UK time)
i cant find how to use gmax if someone can help plz do
24 January 2005 19:45 (UK time)
if u go to www.cncden.com there is a map tutorial, it helps alot.
when u get there click on renegade files on the side bar then click on Ren map tutorial and it will explain everything you would need to know.
bryan919
25 January 2005 04:06 (UK time)
thanks razorblade
