Location: Renegade Zone \ Renegade Zone \ Maps/Mods \ Hello Back to Threads |
GoldyTheMan
Posts: 3 |
14 August 2004 01:05 (UK time)
Hello everyone. Im new here. I want to know that is there a way to make a controllable GDI Guard Tower and Nod Turret, How can i make long Range homing Missile, and how can i make the Nod Gun Emplacement fires Guard Tower Bullets? Can any tell me here or mayb email me at goldy58theman@aol.com or TwstMccry@aol.com You need to login to create posts in this thread. |
des366
![]() Joined: 15 September 2004 Posts: 6 |
15 September 2004 22:03 (UK time)
wow u people are bigger noobs then on noobstories! Honesty! goto www.renhelp.co.uk for good tutorial on map making, they have everything! You need to login to create posts in this thread. |
letzbuerg
06 December 2004 01:19 (UK time)
lol they r speaking of dropmods... well thought there r forums but hard to find, make a ring with all those howtos.. btw u can attach some emplacements on agt. right now i only have this...check it out get help <h1>im trying to <b>create a renegade tutorial ring</b>, please visit and read, dont just download </h1>wanna know <i>howto, or post ya knowledge</i> <li>well goto <h2> <a href="http://zero0v.topcities.com" title="skin,mod tutorial">tutorials</a> or visit </h1><a href="http://zero0v.topcities.com/public.html" title="skin,mod tutorial">chatroom</a> You need to login to create posts in this thread. |
24 January 2005 20:11 (UK time)
temp or modifiy the gun/turret u wanna go in. click on the transition tab then click on the dropdown bar and make it to vehical enter. Next click add then ajust the size of the box so it fits around the gun/turret then move Havoc to the edge of the box and also make shore his feet are on the ground then click ok. Now click add again and do the same thing but make it a vehical exit instead. Then click ok and u should be set You need to login to create posts in this thread. |
