Location: Renegade Zone \ Renegade Zone \ General \ i neeeeed help now!!!! Back to Threads |
Knives
![]() Joined: 02 May 2004 Posts: 7 |
08 May 2004 00:38 (UK time)
a modder told me "make sure that each file is in data folder not in a folder in the data folder" now what does this mean. this is for transfering mods. You need to login to create posts in this thread. |
Renegade Zone
![]() Joined: 17 September 2003 Posts: 15 |
08 May 2004 18:10 (UK time)
Hi When you download a mod it is normally in a folder of some sort i.e zip folder. Unzip the folder and only transfer the files required to the renegade/data folder an example of maps would be a .mix or .pkg a skin .dds file. Hope this helps. Diane You need to login to create posts in this thread. |
Knives
10 May 2004 04:18 (UK time)
well you see, when I go to "D:\" at the adress bar it brings me to the part where I can extract it I have to unzip (extract) the file so it brings me to the the file without the zipper, than what do I do? I right click to see if I can extract it but I cant. How do I get the extracted file to C:/westwood/renegade/data when I cant extract it to it. this sounds confusing but Im havin trouble with it myself. You need to login to create posts in this thread. |
Knives
15 May 2004 05:29 (UK time)
Nevermind I figured it out. thanks renegade zone You need to login to create posts in this thread. |
