Renegade Zone  \  Renegade Zone  \  Strategy/Tactics  \  Blocking
Viewing Thread: Blocking
30 December 2005 23:02 (UK time)
When someone on your team says that the enemy is going to rush. What you do is a trick called blocking. This works the best on a map with Base Defences. All you do is grap a tank and turn it sideways. When the rushers enter your base you drive your vehical infront of theirs and that will halt the rush for a few moments. Your teamates can use this time to get engineers into important structures. If the map has a BD, then as you hold them, the BD will rip them apart.
