Renegade Zone  \  Renegade Zone  \  General  \  probs
Viewing Thread: probs
blueseb
25 September 2005 13:07 (UK time)
when i go to join ppls servers it sometimes says op time out or firewall negostion failed how do i join if it says these things ?
also wo has a renegade fds i can have please i really wont on
14 November 2005 23:32 (UK time)
first of all you cant join a server that says negotating port failed or operation timed out its prolly a bad server or your computer is set for what they have it and wtf you mean renegade fds..
123hijim
15 February 2006 11:04 (UK time)
um you should check out the connection at the end of the bar and see if the numbers are theese colors
red:very bad server
yellow:has a chanse of failing and a temp. bad server
green:good server but sometimes and very rarely will fail
