Location: Renegade Zone \ Renegade Zone \ General \ Uploader working now? Back to Threads |
![]() Joined: 13 November 2003 Posts: 90 |
23 September 2005 01:30 (UK time)
Is the uploader workin now? It looks different but thought I'd ask first. And if it's not then is there someone i shud email the mod to? You need to login to create posts in this thread. |
![]() Joined: 17 September 2003 Posts: 1309 |
23 September 2005 21:04 (UK time)
It is a whole new upload system. It is much better than it used to be and it can handle much larger files with a degree of reliability. Some people have some issues but give it a try. You need to login to create posts in this thread. |
24 September 2005 02:05 (UK time)
Ok, I'll give it a whirl. Edit: Alright I uploaded and it said it worked. Did you recieve? Edited: 24 September 2005 02:08 You need to login to create posts in this thread. |
30 September 2005 14:25 (UK time)
Anyone know if it worked? You need to login to create posts in this thread. |
01 October 2005 13:45 (UK time)
Yes it worked very well and we got your files. There should be an update soon but I can't be sure as I don't do the mod updates for the site myself. We need to mame some changes to the uploader (just simple ones)... - Add an author name box - Add an "are you the author box" - Add a "your email address box" - State that only ZIP files are accepted that that any other archives (rar,ace etc) will be ignored. James You need to login to create posts in this thread. |
01 October 2005 16:20 (UK time)
Good idea, though most people already put the author in the readme :-/. Glad its working though. You need to login to create posts in this thread. |
